Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 4
Flip the motherboard over. Using a plastic opening tool, pry the corners of the x-shaped metal piece  so that they each detach from the motherboard. Be sure to pry each metal corner up slowly to avoid damaging the motherboard.
  • Flip the motherboard over.
  • Using a plastic opening tool, pry the corners of the x-shaped metal piece so that they each detach from the motherboard.
  • Be sure to pry each metal corner up slowly to avoid damaging the motherboard.
  • It is not recommended to use screwdriver/other metal tools not meant to pry things open. Use an opening tool or spudger.
Insertar traducción aquí
