Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 2
Using a T9 Torx screwdriver, remove the four 9mm screws that are holding the heat sink to the outer metal casing. Using a T9 Torx screwdriver, remove the four 9mm screws that are holding the heat sink to the outer metal casing. Using a T9 Torx screwdriver, remove the four 9mm screws that are holding the heat sink to the outer metal casing.
  • Using a T9 Torx screwdriver, remove the four 9mm screws that are holding the heat sink to the outer metal casing.
Insertar traducción aquí
