Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 2
Flip the console back over, keeping in mind the disc drive is loose. Lift the disc drive up so that its metal tab is unhooked from the power supply. Flip the disc drive over and place it on the power supply. The disc drive should end up facing the opposite direction it started in.
Move the disc drive
  • Flip the console back over, keeping in mind the disc drive is loose.
  • Lift the disc drive up so that its metal tab is unhooked from the power supply.
  • Flip the disc drive over and place it on the power supply. The disc drive should end up facing the opposite direction it started in.
  • The disc drive is plugged into the motherboard. Avoid pulling and bending the cables more than necessary to prevent damage.
Insertar traducción aquí
