Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Paso 7
On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws. Remove both of these 7mm screws with a Torx T9 screwdriver. Lift the detached plate off to the side.
  • On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws.
  • Remove both of these 7mm screws with a Torx T9 screwdriver.
  • Lift the detached plate off to the side.
  • The plate is still connected to the device.
Insertar traducción aquí
