Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Paso 6
Pull the upper edge of the white clip down, and then remove the white connector from the dislocated panel using precision tweezers. Do not force the connector out, as it is fragile. Wiggling may be necessary.
  • Pull the upper edge of the white clip down, and then remove the white connector from the dislocated panel using precision tweezers.
  • Do not force the connector out, as it is fragile. Wiggling may be necessary.
Insertar traducción aquí
