Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Paso 4
Using a T9 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing. Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel. Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
  • Using a T9 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing.
  • Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
Insertar traducción aquí
