Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Lift the cellular data antenna out of its recess in the iPad casing. Gently pull the cellular data antenna cable through the channel cut in the rear panel, and remove the antenna from the device.
  • Lift the cellular data antenna out of its recess in the iPad casing.
  • Gently pull the cellular data antenna cable through the channel cut in the rear panel, and remove the antenna from the device.
Insertar traducción aquí
