Saltar al contenido principal
Inglés
Español
Paso 9
We will now focus on opening the heart of the Barista: the boiler. Remove the four hex bolts securing the brew head to the boiler assembly. Lift the brew head off the boiler.
  • We will now focus on opening the heart of the Barista: the boiler.
  • Remove the four hex bolts securing the brew head to the boiler assembly.
  • Lift the brew head off the boiler.
  • Remove the single Phillips screw securing the brew screen and gasket to the boiler housing.
  • The brew screen helps to evenly disperse water across the grounds in the basket.
  • Use a a large standard screwdriver (we used a washer and a pair of pliers) to remove the one-way valve spring retainer from the bottom of the boiler.
  • The one-way valve spring is tuned to only allow the valve to open when the pump is running. This prevents the brew head from dripping while warming up.
Insertar traducción aquí
