Saltar al contenido principal
Inglés
Español
Paso 8
Use an 8 mm bit driver to remove the four hex bolts from around the perimeter of the boiler (only two are shown). Remove the 2 mm hex set screw from the steam valve knob and pull it away from the piping to remove it from the Barista.
  • Use an 8 mm bit driver to remove the four hex bolts from around the perimeter of the boiler (only two are shown).
  • Remove the 2 mm hex set screw from the steam valve knob and pull it away from the piping to remove it from the Barista.
  • At this point, the boiler is free from the Barista and can be removed.
Insertar traducción aquí
