Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 10
Carefully lift the antenna board out of the clutch assembly. Peel the three self-adhesive flaps off the plastic cover on the underside of the antenna board. Remove the protective plastic cover from the antenna board.
  • Carefully lift the antenna board out of the clutch assembly.
  • Peel the three self-adhesive flaps off the plastic cover on the underside of the antenna board.
  • Remove the protective plastic cover from the antenna board.
Insertar traducción aquí
