Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 25 guías que incluyan este paso.
Inglés
Español
Paso 3
Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
  • Rotate the computer 90 degrees clockwise, so that the power receptacle faces you.
  • Remove the three 3 mm Phillips screws.
  • When replacing these screws, you must place each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
Insertar traducción aquí
