Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Lift the case from the bottom side. NOT the side with the hinges. When you feel resistance, do NOT keep lifting or you will damage the housing. Once you feel resistance, gently pull the case towards you. (away from the hinges.)
  • Lift the case from the bottom side. NOT the side with the hinges.
  • When you feel resistance, do NOT keep lifting or you will damage the housing.
  • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
  • Remove the case.
Insertar traducción aquí
