Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
This is the battery.   For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in. Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal. Remove 4 J1 Philips screws.
  • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
  • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
  • Remove 4 J1 Philips screws.
  • Remove 1 J1 philips screw
  • Do not mix these screws up, as if you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
  • slightly lift the battery using your plastic opening tool.
  • Do not lift the battery out all the way, as it is still connected to the motherboard.
  • Do NOT puncture or deform the battery or it may catch fire or even explode.
Insertar traducción aquí
