Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
No hay imagen
Download the Required Files.
  • You will need ODIN, Found at: https://odindownload.com/ Odin3.09 is the more stable version.
  • You will need Your Required Firmware, Found at: https://www.sammobile.com/ You will need to sign up, and log in to download firmware from this site. it is all OEM stock. this site is not for custom ROMS.
  • If your ROM is not located here, you can try to find it at https://forum.xda-developers.com/. this place also does custom ROMS. (PLEASE BE ADVISED: Custom ROM work, if done improperly, can cause failures in device. DO NOT use this source if you do not have experience with software reloads )
Insertar traducción aquí
