Saltar al contenido principal
Inglés
Español
Paso 8
Slowly lift the left edge of the daughterboard up, pulling the antenna patch off of the loudspeaker. You can insert an opening pick under the antenna patch to help separate it from the loudspeaker. If the antenna patch begins to rip, stop pulling. Heat an iOpener, apply it to the corner for a minute, and use an opening pick to help remove it from the loudspeaker.
  • Slowly lift the left edge of the daughterboard up, pulling the antenna patch off of the loudspeaker.
  • You can insert an opening pick under the antenna patch to help separate it from the loudspeaker.
  • If the antenna patch begins to rip, stop pulling. Heat an iOpener, apply it to the corner for a minute, and use an opening pick to help remove it from the loudspeaker.
Insertar traducción aquí
