Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 3
In this step you will remove the three pieces of tape securing the right cell antenna cable to the rear case. Use the tip of a spudger to start each piece, and then the flat end to smoothly peel the tape up without tearing it. Use the tip of a spudger to start each piece, and then the flat end to smoothly peel the tape up without tearing it.
  • In this step you will remove the three pieces of tape securing the right cell antenna cable to the rear case.
  • Use the tip of a spudger to start each piece, and then the flat end to smoothly peel the tape up without tearing it.
Insertar traducción aquí
