Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
We're betting the opening procedure will be the same as it was on the iMac 5K—which is to say, if you can use a pizza cutter, you can open an iMac Pro. With all that glass out of the way,  we have a perfect view of the iMac Pro's pristine interior. Say, wouldn't this make a lovely wallpaper for someone? With all that glass out of the way,  we have a perfect view of the iMac Pro's pristine interior. Say, wouldn't this make a lovely wallpaper for someone?
  • We're betting the opening procedure will be the same as it was on the iMac 5K—which is to say, if you can use a pizza cutter, you can open an iMac Pro.
  • With all that glass out of the way, we have a perfect view of the iMac Pro's pristine interior. Say, wouldn't this make a lovely wallpaper for someone?
Estamos apostando a que el procedimiento de apertura será el mismo que en el iMac 5K, es decir, si puede usar un cortador de pizza, puede abrir un iMac Pro.
Con todo ese vidrio fuera del camino, tenemos una vista perfecta del interior prístino del iMac Pro. Diga, ¿no sería esto un bonito fondo de pantalla para alguien?
