Saltar al contenido principal
Inglés
Español
Paso 5
This may not work if your battery is older, even if it is OEM. Run Command Prompt as an administrator. Enter powercfg /batteryreport. When the report is ready, you will receive a message stating where it is located. Check the data for consistency.
(Windows 10) Battery health check
  • This may not work if your battery is older, even if it is OEM.
  • Run Command Prompt as an administrator. Enter powercfg /batteryreport.
  • When the report is ready, you will receive a message stating where it is located. Check the data for consistency.
Reemplaza la batería si la capacidad es inconsistente.
Ejecuta Command Prompt como un administrador. Ingresa este comando: powercfg/batteryreport.
Cuando el reporte esté listo, recibirás un mensaje notificándote donde está localizado. Verifica si los datos son consistentes.
-[title] Battery health check (Windows 10)
-[* icon_caution] ***''Replace the battery if the capacity is inconsistent.''***
-[* red] Run Command Prompt as an administrator. Enter this command: ***''powercfg/batteryreport.''***
+[title] (Windows 10) Battery health check
+[* icon_caution] ***''This may not work if your battery is older, even if it is OEM.''***
+[* red] Run Command Prompt as an administrator. Enter ***''powercfg /batteryreport.''***
[* orange] When the report is ready, you will receive a message stating where it is located. Check the data for consistency.
