Saltar al contenido principal
Inglés
Español
Paso 6
This will fully discharge the battery. HP diagnostics do not check the charge capacity. Plug the laptop in and turn it on; unplug it once it is on. Press ESC and select System Diagnostics. Open the Component tests submenu. Select Memory or Hard Drive.
(HP UEFI) 15% lockout bypass
  • This will fully discharge the battery. HP diagnostics do not check the charge capacity.
  • Plug the laptop in and turn it on; unplug it once it is on. Press ESC and select System Diagnostics.
  • Open the Component tests submenu. Select Memory or Hard Drive.
  • Select Extensive test. Choose Loop until error.
  • When the laptop shuts off, immediately recharge the battery.
Esto descargará la batería por completo. El diagnóstico de HP no verifica la carga de la batería.
Enchufa la computadora portátil y enciéndela; desenchúfala una vez que esté encendida. Presiona ESC y selecciona Diagnóstico del Sistema.
Abre el submenú Component tests. Selecciona Memory o Hard Drive.
Selecciona Extensive test. Elige Loop until error.
Cuando la computadora portátil se apague, inmediatamente recarga tu batería.
-[title] (UEFI BIOS) HP 15% lockout bypass
-[* icon_caution] ***''This will fully discharge the battery. The HP diagnostics do not check the battery charge.''***
+[title] (HP UEFI) 15% lockout bypass
+[* icon_caution] ***''This will fully discharge the battery. HP diagnostics do not check the charge capacity.''***
[* red] Plug the laptop in and turn it on; unplug it once it is on. Press ***''ESC''*** and select ***''System Diagnostics''***.
[* orange] Open the ***''Component tests''*** submenu. Select ***''Memory or Hard Drive''***.
[* yellow] Select ***''Extensive test''***. Choose ***''Loop until error''***.
[* green] ***''When the laptop shuts off, immediately recharge the battery.''***
