Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 21
Paso 21
Samsung Galaxy Note 10.1 Repairability Score: 8 out of 10 (10 is easiest to repair). Once the rear case is off, most components can be individually replaced without removing any other parts.
  • Samsung Galaxy Note 10.1 Repairability Score: 8 out of 10 (10 is easiest to repair).
  • Once the rear case is off, most components can be individually replaced without removing any other parts.
  • The front glass and LCD can be replaced separately, thereby reducing the cost of fixing your Note should you drop it onto concrete in just the right way.
  • All screws are Phillips #0, and there are only five different length screws.
  • Components are modular. The absence of complicated ribbon cables makes replacing individual components easy.
  • The rear case is held on by a lot of clips and a couple screws. There is no adhesive, but the clips can be tricky to dislodge properly.
  • In order to remove the battery, you first have to disconnect four cables and some tape.
  • The inner frame and some other components are held in with more adhesive than we feel is necessary.
Insertar traducción aquí
