Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Remove the single 28 mm T10 Torx screw securing the left speaker to the rear case. Lift the left speaker up and out of the rear case. Don't try to slide the speaker out, since there is a plastic mounting pin under the top end of the speaker housing that holds it in place.
  • Remove the single 28 mm T10 Torx screw securing the left speaker to the rear case.
  • Lift the left speaker up and out of the rear case. Don't try to slide the speaker out, since there is a plastic mounting pin under the top end of the speaker housing that holds it in place.
Insertar traducción aquí
