Saltar al contenido principal
Inglés
Español
Traduciendo paso 6
Paso 6
Use a spudger to remove the loudspeaker and the charging port. There is some adhesive underneath and the unit might be a little bit sticky. Use a tweezer to loosen the glued in vibration motor and remove it. If you're having a hard time while removing the loudspeaker or the vibration motor you can use an iOpener to loosen the adhesive and try it again.
  • Use a spudger to remove the loudspeaker and the charging port. There is some adhesive underneath and the unit might be a little bit sticky.
  • Use a tweezer to loosen the glued in vibration motor and remove it.
  • If you're having a hard time while removing the loudspeaker or the vibration motor you can use an iOpener to loosen the adhesive and try it again.
  • Before reassembly check your new part for any components that might need to be transferred from the old one.
  • When reassembling your phone, replace old adhesive with stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
Usa un spudger para quitar el altavoz y el puerto de carga. Hay un poco de adhesivo debajo y la unidad puede estar un poco pegajosa.
Usa una pinza para soltar el motor de vibración pegado y remuévelo.
Si estás teniendo dificultades para retirar el altavoz o el motor de vibración, puedes usar un iOpener para aflojar el adhesivo y volver a intentarlo.
Antes de volver a montar, comprueba tu nueva pieza para ver si hay componentes que deban transferirse de la anterior.
[* black] Use a spudger to remove the loudspeaker and the charging port. There is some adhesive underneath and the unit might be a little bit sticky.
[* black] Use a tweezer to loosen the glued in vibration motor and remove it.
[* icon_note] If you're having a hard time while removing the loudspeaker or the vibration motor you can use an [product|IF145-198-8|iOpener|new_window=true] to loosen the adhesive and try it again.
[* icon_reminder] Before reassembly check your new part for any components that might need to be transferred from the old one.
+[* icon_reminder] When reassembling your phone, replace old adhesive with [guide|137171|stretch release adhesive strips], [product|IF317-072|double-sided tape|new_window=true], or [guide|113604|pre-cut adhesive strips|new_window=true].
