Saltar al contenido principal
Inglés
Español
Paso 5
Use a spudger to carefully lever up the daughterboard and remove it. Don't break the small clamps that hold down the daughter board but press them a little bit to the side to make the removal easier. Use a spudger to carefully lever up the daughterboard and remove it. Don't break the small clamps that hold down the daughter board but press them a little bit to the side to make the removal easier.
  • Use a spudger to carefully lever up the daughterboard and remove it. Don't break the small clamps that hold down the daughter board but press them a little bit to the side to make the removal easier.
Usa un spudger para levantar con cuidado la placa hija y retírala . No rompas las pequeñas abrazaderas que sostienen la placa hija, sino que presiona un poco hacia un lado para facilitar la extracción.
