Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the eight Phillips #00 screws that hold the motherboard in its place. Unplug the antenna cable with a tweezer. After you removed all screws there are still small clamps which hold the motherboard in its place. Don't break them while removing it but press them a little bit to the side to make the removal easier.
  • Remove the eight Phillips #00 screws that hold the motherboard in its place.
  • Unplug the antenna cable with a tweezer.
  • After you removed all screws there are still small clamps which hold the motherboard in its place. Don't break them while removing it but press them a little bit to the side to make the removal easier.
  • Use a spudger to carefully lift up the motherboard including all components holding onto it and remove it.
Remueve los ocho tornillos Phillips #00 que sujetan la placa madre en su lugar.
Desenchufa el cable de antena con una pinza.
Después de retirar todos los tornillos, todavía quedan pequeñas abrazaderas que sujetan la placa madre en su lugar. No los rompas mientras los retiras, sino que presiona un poco hacia un lado para facilitar la extracción.
Use un spudger para levantar con cuidado la placa madre, incluidos todos los componentes que la sostienen y remuévela.
