Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone. Useful tip: a penny or dime works in a pinch if you can't use your thumbnail. Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
  • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
  • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
Insertar traducción aquí
