Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 3
Pry under the left edge of the home button cable connector to disconnect it from its socket. If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor. If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
  • Pry under the left edge of the home button cable connector to disconnect it from its socket.
  • If the entire connector begins to flip up without separating, press down on the cable at the top edge of the connector with the flat of your spudger, while simultaneously prying up the left edge of the connector. Be very careful not to damage the cable or connector, or you will permanently disable the sensor.
Haz palanca por debajo del borde izquierdo del conector de cable de botón de inicio para desconectarlo de su zócalo.
Si el conector completo comienza a darse vuelta sin separarse, presiona el cable en el borde superior del conector con la parte plana de tu spudger, mientras simultáneamente levantas el borde izquierdo del conector. Ten mucho cuidado de no dañar el cable o conector o el sensor se inutilizará de manera permanente.
