Saltar al contenido principal
Inglés
Español
Paso 3
a few back and forth strokes of your soldering iron should be enough to remove the flex cable.
Remove the flex
  • a few back and forth strokes of your soldering iron should be enough to remove the flex cable.
  • be sure not to apply too much force with the iron, as you can cause physical damage to the pads.
  • Using a little bit of solder flux, can help decrease the amount of pressure needed to properly transfer the heat.
Insertar traducción aquí
