Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Use the spudger to lift the motherboard up and remove it from the laptop, then flip the now separated motherboard over. Using tweezers, disconnect the red wire circled in the picture; where the hard drive would be. Locate the SSD and the screw holding it in.
  • Use the spudger to lift the motherboard up and remove it from the laptop, then flip the now separated motherboard over.
  • Using tweezers, disconnect the red wire circled in the picture; where the hard drive would be.
  • Locate the SSD and the screw holding it in.
  • Unscrew the one Screw using a #1 Phillips Head screwdriver.
  • The SSD will want to lift with that screw being removed, from here grab it and pull it out gently.
Insertar traducción aquí
