Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
First, locate all the ribbon cables that are connected to the motherboard. Lift the ribbon cable connector tabs with the spudger gently. Using the tweezers, gently pull back on the ribbon cable until it is completely out of the socket.
  • First, locate all the ribbon cables that are connected to the motherboard.
  • Lift the ribbon cable connector tabs with the spudger gently.
  • Using the tweezers, gently pull back on the ribbon cable until it is completely out of the socket.
  • Be very gentle while dealing with ribbon cables. If one gets damaged the component it links to will not function.
Insertar traducción aquí
