Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Locate the battery. Wedge the spudger underneath the battery, and apply pressure to lift it away from the rest of the device. Gently pull and wiggle the multiple colored wired connector out from the socket.
  • Locate the battery.
  • Wedge the spudger underneath the battery, and apply pressure to lift it away from the rest of the device.
  • Gently pull and wiggle the multiple colored wired connector out from the socket.
  • If you are removing the original battery, the back has a couple foam strips that were installed for cushioning. Those can be carefully removed and placed on the new replacement battery, but it is not necessary.
Insertar traducción aquí
