Saltar al contenido principal
Inglés
Español
Paso 5
Remove the single Phillips Screw. Bend the tabs inward with needle nose pliers to mirror the shape of the hole below it. Be careful not to bend these tabs too much or too far, for they break off easily if bent back and forth too many times.
Front Panel and Lever
  • Remove the single Phillips Screw.
  • Bend the tabs inward with needle nose pliers to mirror the shape of the hole below it.
  • Be careful not to bend these tabs too much or too far, for they break off easily if bent back and forth too many times.
  • Lift the lever out of the tab.
  • Carefully pull the front panel and lever out the front of the base.
Insertar traducción aquí
