Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 5
Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
  • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
  • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
  • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
Insertar traducción aquí
