Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Paso 2
Once the edge is warm to the touch, apply a suction cup close to the edge. Lift on the suction cup, and insert an opening pick into the gap. Do not insert the pick more than 13 mm (0.5 inches), or you will damage the display assembly.
  • Once the edge is warm to the touch, apply a suction cup close to the edge.
  • Lift on the suction cup, and insert an opening pick into the gap.
  • Do not insert the pick more than 13 mm (0.5 inches), or you will damage the display assembly.
  • If you have trouble creating a gap, reheat the edge and try again.
  • You can also try to use a playing card instead of an opening pick to help make the initial entry.
Insertar traducción aquí
