Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Heat an iOpener and apply it to the top edge of the display for two minutes. A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage. Take note of the following regions before you begin prying:
  • Heat an iOpener and apply it to the top edge of the display for two minutes.
  • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  • Take note of the following regions before you begin prying:
  • Thin adhesive lined against the display panel
  • Thick adhesive
  • The OLED display panel, which is very prone to damage
  • The display cable, which can be damaged during prying
Insertar traducción aquí
