Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 10 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body. Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
  • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
  • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
  • Remove the cover.
Quita la tapa trasera insertando la herramienta de apertura de plástico en las bisagras y calzándola entre la tapa trasera y el cuerpo.
Sigue a lo largo del borde trasero con la herramienta de apertura de plástico, levantando la tapa a medida que avanzas. Es normal escuchar sonidos de chasquidos y clics cuando la tapa trasera se sujeta con clips.
Remueve la tapa.
