Saltar al contenido principal
the GEN 2 Wheelchair Tire Replacement
Qué necesitas
  1. the GEN 2 Wheelchair Tire Replacement, Tire Inner Tube: paso 1, imagen 1 de 3 the GEN 2 Wheelchair Tire Replacement, Tire Inner Tube: paso 1, imagen 2 de 3 the GEN 2 Wheelchair Tire Replacement, Tire Inner Tube: paso 1, imagen 3 de 3
    • Remove the flat tire by loosening and removing the axle nut with a 19 mm wrench.
    • Unscrew the axle bolt with a 19 mm socket wrench.
    • Remove the axle bolt from hole and remove the wheel from the wheelchair.
  2. the GEN 2 Wheelchair Tire Replacement: paso 2, imagen 1 de 2 the GEN 2 Wheelchair Tire Replacement: paso 2, imagen 2 de 2
    • Insert the 19 mm socket wrench between the rubber tire and the metal frame.
    • Any rigid flat object will do for this step.
    • Carefully run the 19 mm socket wrench along the edge of the tire all the way around and bend the wrench down to pop the tire out of the rim.
    • When undoing the tire, be careful using the back of the wrench because the tool can damage the tire tube and or wheel frame.
    • Reach inside the tire and remove the tube from the metal frame.
    • Carefully feed the air valve through the hole in the rim before removing, or you could tear a larger hole in the tire.
  3. the GEN 2 Wheelchair Tire Replacement: paso 3, imagen 1 de 1
  4. the GEN 2 Wheelchair Tire Replacement: paso 4, imagen 1 de 1
    • Before replacing the tube, feel along the tire to check for and remove any objects stuck in the tire.
    • Line up the air valve on the new (partially deflated) tube with the hole on the metal frame.
    • Working all around the tire, carefully push the tube back into place inside the tire.
    • Finally, push the tire back into place on the metal frame and inflate the tire.
    • The tire should be inflated to 50 psi and very hard.
  5. the GEN 2 Wheelchair Tire Replacement: paso 5, imagen 1 de 2 the GEN 2 Wheelchair Tire Replacement: paso 5, imagen 2 de 2
    • Insert the axle bolt into center of rear wheel.
    • Insert the wheel with the axle bolt into the lower back of the frame.
  6. the GEN 2 Wheelchair Tire Replacement: paso 6, imagen 1 de 2 the GEN 2 Wheelchair Tire Replacement: paso 6, imagen 2 de 2
    • Screw the bolt on the outside of the wheel with a 19 mm socket wrench.
    • Screw the nut on the inside of the wheel with a 19 mm wrench.
Conclusión
Una persona más ha completado esta guía.
Kali Slaughter
Miembro Desde 04/19/13
207 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 14-8, Maness Spring 2013 Miembro de Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 3,062
