Saltar al contenido principal
Introducción
it`s easy and very quick replacement. it could be completed even with fingerskate screwdriver, but i used simple philips 1,7 from my toolkit.
Partes
No se especificaron partes.
  1. samsung sgh x820 samsung sgh x820 samsung sgh x820
    • samsung sgh x820
  2. after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver. after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver. after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
    • after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. now we have two more screws hiden first time i used needle. this time i took a blade. removing the last two philipps-head screws.
    • now we have two more screws hiden
    • first time i used needle. this time i took a blade.
    • removing the last two philipps-head screws.
  5. be carefull. the phone is thin and you should push on two hooks two open cover case.
    • be carefull. the phone is thin and you should push on two hooks two open cover case.
  6. now you should take of the square metal  in the middle of your phone to eject display.
    • now you should take of the square metal in the middle of your phone to eject display.
    • i used plastic spudger
  7. the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
    • the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
Conclusión
3 personas más completaron esta guía.
sergeygraf
Miembro Desde 24/10/10
161 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 1,161
