Introducción
Is your ring Indoor Cam's camera malfunctioning, the image not showing clearly, or not showing at all? Then, you can use this guide as a walkthrough to replace the camera.
While replacing the camera you will need to detach small white leads from sockets on the motherboard, so make sure to handle them with care.
While doing so you'll need to make sure your Indoor Cam isn't connected to any electrical circuits and that you're using ESD-safe tools in order to avoid electrical injuries
Qué necesitas
Place the cam with the base facing towards you.
Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
Remove the base from the rest of the camera.
Gently remove the three white leads from their sockets on the top of the motherboard.
Gently turn to the motherboard's backside and remove the white leads connecting the camera to the socket in the motherboard.
Cautiously remove the camera.
