Saltar al contenido principal
plantronics Voyager pro Battery Replacement
Qué necesitas
Resumen del Video
  1. plantronics Voyager pro Battery Replacement, Battery: paso 1, imagen 1 de 1
    • order your battery
  2. plantronics Voyager pro Battery Replacement: paso 2, imagen 1 de 1
    • separate rubber case from back of earpiece. you don't need to remove it completely like I did.
  3. plantronics Voyager pro Battery Replacement: paso 3, imagen 1 de 1
    • rotate the back away from the case. its basically glued in place with no other fasteners
  4. plantronics Voyager pro Battery Replacement: paso 4, imagen 1 de 1
    • you will need to slowly cut through the foam to separate the wires from the battery. then use a soldering iron to desolder the old battery from the board these connections go through the entire board.
  5. plantronics Voyager pro Battery Replacement: paso 5, imagen 1 de 1
    • solder the new battery in and test the charging before reassembly.
    • the new battery I ordered was slightly larger but it fit with no problems. I found the wires inside this device to be fairly robust and did not have any issues with wires breaking or dislodging.
    • When I re-assembled I used small amounts of gorilla glue for both the case and the rubber cover. it worked very well and has worked well since. for more details I put together a short video you can check out.
Conclusión
5 personas más completaron esta guía.
Dan Dunham
Miembro Desde 04/15/17
3,327 Reputación
29 Guías creadas
Un comentario
I accomplished this battery replacement. I was successful. However in my opinion, this device was not meant to have this repair done. It is a “fiddley” affair, but possible. I think it took me two hours, at my leisure. Probably better off replacing the device. Unless…. your just that type who enjoys fiddling around.
Leslie Womelsdorff - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 19
Ultimos 30 días: 84
Todo El Tiempo: 4,546
