Saltar al contenido principal
nikon s3700 LCD Display Screen Replacement
Qué necesitas
  1. nikon s3700 LCD Display Screen Replacement, Removing the Screws: paso 1, imagen 1 de 3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: paso 1, imagen 2 de 3 nikon s3700 LCD Display Screen Replacement, Removing the Screws: paso 1, imagen 3 de 3
    • group screws according to color code.
    • Remove exterior screws
  2. nikon s3700 LCD Display Screen Replacement, Replace LCD: paso 2, imagen 1 de 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: paso 2, imagen 2 de 3 nikon s3700 LCD Display Screen Replacement, Replace LCD: paso 2, imagen 3 de 3
    • Remove Rear casing.
    • With a thin blade, gently lift the top tight hand side of the buttons board releasing a peg from a hole on the midframe below. Whilst doing so, gently push on the top left hand side in order to release the buttons board from a clip. At the same time, the bottom left hand corner wil be released from another clip.
    • Flip over rear buttons board to expose LCD ZIF clamp.
    • Flip open the clamp of the ZIF connector and slide the ribbon cable out. (The connector may have a piece of sticky tape over it. Removing this may well open the connector clamping bar.)
    • The ZIF clamp is very fragile so please use caution when releasing the ZIF clamp. It breaks easily.
    • Remove the LCD.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 479
