Introducción
After two years of use the whisk of our milk frother turned only slowly. It could be stopped with one finger. I found an instruction that suggested to change the polarity of the motor by exchanging the connection cables. This worked with our two milk frothers.
Qué necesitas
Remove the three screws with a screwdriver PH2
There is a little triangle impressed in the bottom plate to show the position of the on-switch.
On one side of the plug you see two slots. You can see the cable shoes in there.
With something pointed (eg. watchmaker's screwdriver) you press in one slot to open the cable shoe's locking catch. At the same time you pull on the cable.
Do the same with the second cable.
Exchange the position of the cables and push the cable shoes back in the plug.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ John Maier nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Un comentario
Bei unserem bauähnlichen Milchschäumer Petra ließ sich das gleiche Problem genauso beheben.
