Saltar al contenido principal
ionvac SmartClean V2 Side Brush Motors Replacement
Qué necesitas
  1. ionvac SmartClean V2 Side Brush Motors Replacement, Shell (Top & Bottom): paso 1, imagen 1 de 2 ionvac SmartClean V2 Side Brush Motors Replacement, Shell (Top & Bottom): paso 1, imagen 2 de 2
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Side Brush Motors Replacement: paso 2, imagen 1 de 3 ionvac SmartClean V2 Side Brush Motors Replacement: paso 2, imagen 2 de 3 ionvac SmartClean V2 Side Brush Motors Replacement: paso 2, imagen 3 de 3
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Side Brush Motors Replacement: paso 3, imagen 1 de 1
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Side Brush Motors Replacement: paso 4, imagen 1 de 2 ionvac SmartClean V2 Side Brush Motors Replacement: paso 4, imagen 2 de 2
    • Lift the top shell off carefully.
  5. ionvac SmartClean V2 Side Brush Motors Replacement, Side Brush Motors: paso 5, imagen 1 de 1
    • Identify the 2 side brush motors that look like cylinders on the bottom shelf of your ionvac.
  6. ionvac SmartClean V2 Side Brush Motors Replacement: paso 6, imagen 1 de 2 ionvac SmartClean V2 Side Brush Motors Replacement: paso 6, imagen 2 de 2
    • Remove the 3 screws that attach the motor to the bottom shelf.
    • Lift the motor out of its slot.
  7. ionvac SmartClean V2 Side Brush Motors Replacement: paso 7, imagen 1 de 1
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 165
