Saltar al contenido principal
ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement
  1. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement, Front Wheel (Swivel Caster): paso 1, imagen 1 de 1
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Flip your ionvac upside down so the wheels are pointed upwards.
  2. ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: paso 2, imagen 1 de 2 ionvac SmartClean V2 Front Wheel (Swivel Caster) Replacement: paso 2, imagen 2 de 2
    • Using your thumb and forefinger, grip the flat sides of the wheel and pull it out.
    • If the wheel is stuck, you can use a spudger to pry the caster out.
    • When reinstalling, the wheel should click into place. Before restarting the ionvac, try spinning the wheel with your finger to test its movement.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 69
