Saltar al contenido principal
ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement
Qué necesitas
  1. ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Belt Clip: paso 1, imagen 1 de 2 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Belt Clip: paso 1, imagen 2 de 2
    • Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
  2. ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery Cover: paso 2, imagen 1 de 3 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery Cover: paso 2, imagen 2 de 3 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery Cover: paso 2, imagen 3 de 3
    • Remove the battery cover by gently pushing inward on the arrow on the cover.
    • While maintaining pressure push the cover upward.
  3. ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery: paso 3, imagen 1 de 2 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the Battery from the socket
    • When installing the battery take note of the signs displayed in the socket to determine which direction the negative and positive ends should be.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 345
