Introducción
In this Disassembly guide we tackle the ilo 1gb mp3 player. Its not a particularly difficult project so not many tools or in depth knowledge is required. So lets jump right in!
Qué necesitas
Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
Remove the battery cover by gently pushing inward on the arrow on the cover.
While maintaining pressure push the cover upward.
Under the cover you will find Three (3) 5mm screws that will need to be removed. For this you will need to use the PH00 screw tip included in your iFixit kit. Make sure to keep track of these screws as they will need to be reinserterd during the reassembly of your device.
Una persona más ha completado esta guía.
