Saltar al contenido principal
iView-776TPCII Rear Panel Replacement
Qué necesitas
  1. iView-776TPCII Rear Panel Replacement, Rear Panel: paso 1, imagen 1 de 3 iView-776TPCII Rear Panel Replacement, Rear Panel: paso 1, imagen 2 de 3 iView-776TPCII Rear Panel Replacement, Rear Panel: paso 1, imagen 3 de 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
  2. iView-776TPCII Rear Panel Replacement: paso 2, imagen 1 de 2 iView-776TPCII Rear Panel Replacement: paso 2, imagen 2 de 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
Conclusión
Equipo
IUPUI, Team 2-2, Baechle Fall 2015 Miembro de IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 329
