Saltar al contenido principal
iView-776TPCII Digitizer Replacement
Qué necesitas
  1. iView-776TPCII Digitizer Replacement, Rear Panel: paso 1, imagen 1 de 3 iView-776TPCII Digitizer Replacement, Rear Panel: paso 1, imagen 2 de 3 iView-776TPCII Digitizer Replacement, Rear Panel: paso 1, imagen 3 de 3
    • Before disassembling your device, make sure that the power is completely turned off.
    • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
    • The clips may take some pressure before releasing.
    • Continue around the entire device until all of the clips have been released.
  2. iView-776TPCII Digitizer Replacement: paso 2, imagen 1 de 2 iView-776TPCII Digitizer Replacement: paso 2, imagen 2 de 2
    • Use a spudger to carefully free the speaker from it's housing on the back panel.
    • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
    • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
  3. iView-776TPCII Digitizer Replacement, Battery: paso 3, imagen 1 de 1
    • Insert the flat side of the standard spudger underneath the battery and use a prying action to loosen the glue holding it to the digitizer.
    • Do this all around the battery until it comes off.
    • The glue is strong, so some force may be required. However, be careful not to apply so much pressure that the battery bends or breaks.
    • At this point, do not attempt to fully remove the battery, since it is still connected to the motherboard.
  4. iView-776TPCII Digitizer Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use the Portable Soldering Iron tool to heat the leads coming from the battery to the motherboard, thereby breaking the connection.
    • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
    • Once heated, use tweezers to pull the wires free from their connections.
    • To ease reassembly, take note of which wire went to the positive and negative terminals.
  5. iView-776TPCII Digitizer Replacement, Wi-Fi Antenna: paso 5, imagen 1 de 2 iView-776TPCII Digitizer Replacement, Wi-Fi Antenna: paso 5, imagen 2 de 2
    • Detach the end of the Wi-Fi antenna from the tape on the edge of the shell.
  6. iView-776TPCII Digitizer Replacement: paso 6, imagen 1 de 1
    Comprar
    • Use the Portable Soldering Iron tool to heat the lead coming from the Wi-Fi antenna to the logic board, thereby breaking the connection.
    • Once heated, use tweezers to pull the wire free from its connection.
  7. iView-776TPCII Digitizer Replacement, Camera Assembly: paso 7, imagen 1 de 2 iView-776TPCII Digitizer Replacement, Camera Assembly: paso 7, imagen 2 de 2
    • The camera module is located in the upper-right corner of the tablet.
    • Loosen the edges of the black tape covering the camera using the heavy-duty spudger.
    • Use the freed edges of the tape to gently remove the camera assembly from its plastic housing.
    • The camera assembly will still be connected to the rest of the device via a ribbon cable. Take care so as not to tear this connection.
  8. iView-776TPCII Digitizer Replacement: paso 8, imagen 1 de 2 iView-776TPCII Digitizer Replacement: paso 8, imagen 2 de 2
    Comprar
    • Use tweezers to lift the cover off the top of the camera's ZIF adapter.
    • When reassembling the device, be sure to fully secure the ribbon cable from the camera back into the ZIF adapter.
    • Pull the assembly away from the motherboard with a set of tweezers to prepare for desoldering.
  9. iView-776TPCII Digitizer Replacement: paso 9, imagen 1 de 1
    • Use the Portable Soldering Iron tool to heat the leads coming from the camera assembly to the motherboard, thereby breaking the connection.
  10. iView-776TPCII Digitizer Replacement, Motherboard: paso 10, imagen 1 de 3 iView-776TPCII Digitizer Replacement, Motherboard: paso 10, imagen 2 de 3 iView-776TPCII Digitizer Replacement, Motherboard: paso 10, imagen 3 de 3
    • Remove the three 2.2mm Phillips head screws using a screwdriver to loosen the motherboard from the shell.
    • Check "Screwdriver Best Practices" as needed for help on how to properly use a screwdriver with your device.
  11. iView-776TPCII Digitizer Replacement: paso 11, imagen 1 de 2 iView-776TPCII Digitizer Replacement: paso 11, imagen 2 de 2
    Comprar
    • Use the 45 degree tweezers to lift the black section of the digitizer ZIF adapter to release the ribbon. Gently pull the ribbon cable out of its socket.
    • When reassembling the device, be sure to fully secure the ribbon cable back into the ZIF adapter.
  12. iView-776TPCII Digitizer Replacement: paso 12, imagen 1 de 3 iView-776TPCII Digitizer Replacement: paso 12, imagen 2 de 3 iView-776TPCII Digitizer Replacement: paso 12, imagen 3 de 3
    • Use the 45 degree tweezers to lift the black section of the LCD ZIF adapter to release the ribbon. Gently pull the ribbon cable out of its socket.
    • The motherboard is now separated from the digitizer and front panel and can be safely removed from the device.
  13. iView-776TPCII Digitizer Replacement, Digitizer: paso 13, imagen 1 de 3 iView-776TPCII Digitizer Replacement, Digitizer: paso 13, imagen 2 de 3 iView-776TPCII Digitizer Replacement, Digitizer: paso 13, imagen 3 de 3
    • Insert the plastic opening tool between the digitizer and the screen. Use a prying motion to loosen the digitizer from its plastic case.
    • If you find it hard to separate the two components at first, try to use another plastic opening tool for support.
    • Continue moving along the edge of the digitizer until it is fully separated.
Conclusión
Cory Gratzer
Miembro Desde 09/16/15
570 Reputación
5 Guías creadas
Equipo
IUPUI, Team 2-2, Baechle Fall 2015 Miembro de IUPUI, Team 2-2, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G2
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 590
