Saltar al contenido principal
iVIEW-754TPC Rear Panel Replacement
Qué necesitas
  1. iVIEW-754TPC Rear Panel Replacement, Rear Panel: paso 1, imagen 1 de 3 iVIEW-754TPC Rear Panel Replacement, Rear Panel: paso 1, imagen 2 de 3 iVIEW-754TPC Rear Panel Replacement, Rear Panel: paso 1, imagen 3 de 3
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
Conclusión
Robert Clark
Miembro Desde 01/21/15
1,065 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 5-4, Brown Winter 2015 Miembro de USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 224
