Saltar al contenido principal
iVIEW-754TPC Logic Board Replacement
Qué necesitas
  1. iVIEW-754TPC Logic Board Replacement, Rear Panel: paso 1, imagen 1 de 3 iVIEW-754TPC Logic Board Replacement, Rear Panel: paso 1, imagen 2 de 3 iVIEW-754TPC Logic Board Replacement, Rear Panel: paso 1, imagen 3 de 3
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC Logic Board Replacement, Remove Battery: paso 2, imagen 1 de 3 iVIEW-754TPC Logic Board Replacement, Remove Battery: paso 2, imagen 2 de 3 iVIEW-754TPC Logic Board Replacement, Remove Battery: paso 2, imagen 3 de 3
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  3. iVIEW-754TPC Logic Board Replacement, Camera Assembly: paso 3, imagen 1 de 3 iVIEW-754TPC Logic Board Replacement, Camera Assembly: paso 3, imagen 2 de 3 iVIEW-754TPC Logic Board Replacement, Camera Assembly: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • The camera module is located directly under the top right corner of the back cover.
    • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
    • As you peel the tape backward, the front facing camera may come out, this is not an issue.
    • If the front facing camera does not come out, gently lift it out with a pair of tweezers
  4. iVIEW-754TPC Logic Board Replacement, Remove Camera: paso 4, imagen 1 de 2 iVIEW-754TPC Logic Board Replacement, Remove Camera: paso 4, imagen 2 de 2
    • Use a spudger to lift flap on top of the camera ZIF adapter.
    • At this point the camera module can be easily removed with a pair of tweezers.
    • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
  5. iVIEW-754TPC Logic Board Replacement, Logic Board: paso 5, imagen 1 de 1
    • Remove the four 2.2mm Phillips screws holding the logic board in place. Place the screws on the iFixit magnetic project mat.
  6. iVIEW-754TPC Logic Board Replacement, WIFI Antenna: paso 6, imagen 1 de 2 iVIEW-754TPC Logic Board Replacement, WIFI Antenna: paso 6, imagen 2 de 2
    Comprar
    • Gently peel the WIFI Antenna up using a pair of tweezers.
  7. iVIEW-754TPC Logic Board Replacement, Disconnect LCD: paso 7, imagen 1 de 3 iVIEW-754TPC Logic Board Replacement, Disconnect LCD: paso 7, imagen 2 de 3 iVIEW-754TPC Logic Board Replacement, Disconnect LCD: paso 7, imagen 3 de 3
    • Use a spudger to lift the flap on top of the LCD ZIF socket.
    • Gently remove the ribbon cable from the socket using a tweezers.
  8. iVIEW-754TPC Logic Board Replacement, Disconnect Digitizer: paso 8, imagen 1 de 3 iVIEW-754TPC Logic Board Replacement, Disconnect Digitizer: paso 8, imagen 2 de 3 iVIEW-754TPC Logic Board Replacement, Disconnect Digitizer: paso 8, imagen 3 de 3
    • Use a spudger to lift the flap on top of the digitizer ZIF socket.
    • Gently pull the tape attached to the ribbon cable to remove the cable from its socket.
  9. iVIEW-754TPC Logic Board Replacement, Remove Logic Board: paso 9, imagen 1 de 3 iVIEW-754TPC Logic Board Replacement, Remove Logic Board: paso 9, imagen 2 de 3 iVIEW-754TPC Logic Board Replacement, Remove Logic Board: paso 9, imagen 3 de 3
    • Gently slide the spudger below the logic board at the left side nearest the battery. Lift upward and away from the power button and bottom connectors.
    • The battery is still attached to the logic board. Be careful to not tear the two apart during removal.
Conclusión
Robert Clark
Miembro Desde 01/21/15
1,065 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 5-4, Brown Winter 2015 Miembro de USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 924
