Saltar al contenido principal
iVIEW-754TPC Battery Replacement
Qué necesitas
  1. iVIEW-754TPC Battery Replacement, Rear Panel: paso 1, imagen 1 de 3 iVIEW-754TPC Battery Replacement, Rear Panel: paso 1, imagen 2 de 3 iVIEW-754TPC Battery Replacement, Rear Panel: paso 1, imagen 3 de 3
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC Battery Replacement, Remove Battery: paso 2, imagen 1 de 3 iVIEW-754TPC Battery Replacement, Remove Battery: paso 2, imagen 2 de 3 iVIEW-754TPC Battery Replacement, Remove Battery: paso 2, imagen 3 de 3
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  3. iVIEW-754TPC Battery Replacement, Desolder wires: paso 3, imagen 1 de 3 iVIEW-754TPC Battery Replacement, Desolder wires: paso 3, imagen 2 de 3 iVIEW-754TPC Battery Replacement, Desolder wires: paso 3, imagen 3 de 3
    • Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
    • Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
    • To ease reassembly, take note of which wire goes to the negative and positive terminals.
Conclusión
3 personas más completaron esta guía.
calvin
Miembro Desde 01/21/15
188 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 5-4, Brown Winter 2015 Miembro de USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 2,401
